Administrator-level accounts can view and change all switch parameters.
With this privilege level, you can also add and delete users, as well as change the password associated with any account name. To erase the password, use the unconfigure switch all command.
An administrator can disconnect a management session that has been established by way of a Telnet connection. If this occurs, the user logged on through the Telnet connection is notified that the session has been terminated.
If you log on with administrator privileges, the command line prompt ends with a pound or hash (#) sign.
For example: 5420F-48P-4XE.3 #
If you log on with administrator privileges to 4120 and 4220 switches, the command line prompt ends with an equal (=) sign.
